Laguna RT Steering Problem
bwellard
Unread post by bwellard »
I have a 1996 1.8l Laguna RT. Recently it has started to pull to the left when the steering wheel is centred and I'm having to steer to the right to compensate. I had the cars tracking checked yesterday using 4 wheel Laser, yet it is all spot on. Tyre pressures are both fine and it has recently had a full service(3 weeks ago) and passed its MOT at the same time, so would've thought worn suspension components should've been identified at the time.. I do have a knocking sound coming from the front suspension which stopped for a few months after I replaced the anti roll bar, but is back again. Any ideas?
ferkemall
New User
Re: Laguna RT Steering Problem
Unread post by ferkemall »
Check the bottom joints !
ekjdm14
x 266
Unread post by ekjdm14 »
Wow, how many decade-plus aged posts are you replying to? please look at the dates before you post... I would imagine this 1996 Laguna is long scrapped by now, even if it were just the bottom ball joints at that time
'96 ZX SX 1.9TD, White, 88k
'12 Mini freebie project
