Water in Diesel Light
soupy_sam
Unread post by soupy_sam »
I have just serviced my Xantia 1.9 LX TD and the Water in Fuel light is on all the time ignition is on. What have I done or what is wrong?
Sam
adzbaby
Unread post by adzbaby »
Did you replace the fuel filter?
Try draining the filter. But this is a common fault with the sensor, I ignored mine for about a year before I swapped it over from another engine, now it doesn't bother me anymore.
Ignore it! ;)
soupy_sam
Where abouts is the sensor and what is its proper name when asking for a new one at the main dealers
Dave Burns
Unread post by Dave Burns »
If the light wasn't on before you fiddled with it then you have disturbed something, but try lightly cleaning the sensor first with a fine plastic pan scrubber, do not use abrasives such as emery cloth.
Of course the other reason for the light being on is that there may well be water in the fuel.
Dave
soupy_sam
Have not fiddled with it Light was on when we bought vehicle, have had a service at local garage filter changed but light still on.
