hi all can anyone give me a idiots guide for fitting a towbar to a 97
laguna hatch,i'm not an idiot but hav'ant done this before?
laguna towbar
martyhopkirk
If you have teh towbar and the fixings its fairly idiot proof - BUT the back bumper has to come of first to locate the fixing points for the towbar (existing mount points used) and also to pull the wiring cable through to the car. If using an aftermarked 12N / 12S socket set make sure the connectors are watertight and inside the car. Use a multimeter to tell you what lamp is which and also remember to take separate side lamp connections from each side (otherwise you run the risk of overloading the fuse).
Fitted a Towsure one to my 96 RT Sport - took about 6 hours - only due to teh farting about trying to get the bumper off.
timbo
