Hi I have a Xantia with a Clarion PU-9667A radio/casette which appears to be locked. I have disconected the battery but when I reconnect it the radio is still locked can anyone shed any light on how to get this radio working please.
I have the 4 digit unique code ready to put in once I have managed to unlock the unit.
HAVE HAD THE UNIT RECODED THANKS EVERYONE FOR OUR ADVISE
Clarion PU-9667A Radio Casette Xantia Sorted
Evodad
First thing you need is the unique four digit code for your unit. I was given the wrong one when I bought my Xantia, but used this site to get the correct one:-
http://radiocode.proboards6.com/index.c ... =codereqst
martyhopkirk
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by soupy_sam</i>
Cheers<hr height="1" noshade id="quote"></blockquote id="quote"></font id="quote">
If the unit is locked (following the insertion of the incorrect code more than 3 times) you will need to leave it "powered up" for upto 3 hours before it will let you attempt to re enter the code again. BE WARNED - if you fluff up again - it will lock up for another 3 hours. I believe after 10 attempts it siezes solid ("refer to your Citroen Dealer" is teh expression in the manual) though I stand to be corrected on this.
jack.dempsey
Tell me the radio's model/serial number and I'll tell you what the original code was (check also for any stickers which can be affixed warning if its been recoded for any reason - like being permanently locked previously). It sounds as though you think you know the correct code - so if my code is the same you'll be very confident its the right one.
soupy_sam
