Water Reservoir
born2die
Water Reservoir
Unread post by born2die »
How the blazes do you check the water level on an activa the water bottle is solid black plastic????
thanks
Kowalski
Unread post by Kowalski »
There is a white plastic insert (which may be a rusty orange colour) inside the header tank. If you can see water with this white plastic in the tank, there is enough water in. The plastic insert has a cut in the side of it, the bottom of the cut is the "maximum" water level the bottom of the insert is the "minimum" water level.
born2die
thanks
