Hi, The heater fan on my '93 Xantia packed in yesterday[:(]
I had a look at it today, firstly checking the fuse - that was okay!
I then thought that it was the ignition switch at fault, but then thought about the heater resistor. Removed the dash carpet and undid the resistor and low and behold, the wiring had over heated and broke. A play at the scrap yard and for just a couple of quid a replacement resistor and wiring to match.
Cheap and easy to sort out (thank goodness)
Paul[:)][:)]
