Power steering - Problem?
tonyb1
Hi to all. I noticed today when going around corners, I get a noise from the steering wheel area. I can only describe it as the noise you get when you wipe a wet window with your finger, like a dull vibration noise. It's not there all the time and is fairly quiet at the moment. Is it a sign of a problem in it's early stages? Can't find any leaks or anything. Any comments would be appreciated. Thanks.
tonyb1
dan.2cv
My old BMW had an 'earth ring' around the steering wheel hub on which the horn contact would rotate when you turned the wheel. After a while the contact became dry and would emit a really loud 'farty vibration' noise throught the wheel. After removing the wheel and applying some vaseline the problem was cured. Not sure if early Xantias without the steering wheel controls had a similar set up but it might be worth a look. If you haven't got an airbag it's a simple enough job to have a look around anyway, you might even have a dry bearing?
tonyb1
