Air inlet gasket needed?
mipster
Unread post by mipster »
I noticed yesterday that the metal part that bolts onto the inlet manifold and has the pipe from the intercooler connected to it was loose. I dismantaled and refitted it tight but should it have a gasket? has it got a name?
I've wondered for a while if I've been losing performance but put it down to age (mine and the cars :) ), needless to say It;s much better now.
Wookey
(Donor 2019)
x 12
Unread post by Wookey »
Assuming you are talking about the XUD9TE in a Xantia and I have the right manifold in mind then this page:
http://www.elcats.ru/peugeot/detail.asp ... 1%2014N18A
suggests that the answer depends on the vintage. Early ones had no gasket. Later ones, with a bracket, had a seal. That's actually the page for an 806, but so far as I can tell the inlet manifolds are the same.
Has anyone found a parts catalogue for citroen vehicles online yet? Would be handy... I suppose I could buy one of these CDs and put that online, but I suspect you need to have a server in Russia to avoid getting told to take it down (russian copyright law is highly pro-consumer - which is why they can have sites like allofmp3.com which sells music by the megabyte - it's marvellous; and presumably the above parts catalogue).
Kowalski
Unread post by Kowalski »
My '97 Xantia had no gasket and was leaking, so I removed it, cleaned it and used bathroom silicone "instant gasket" to make up the joint, that was over a year ago and I've not had any leakage since.
According to the parts catalogue, there is a gasket but neither the 3 'local' citroen dealers or 2 local Peugeot dealers had them in stock, so I went the bathroom silicone route.
mipster
That's the one (with bracket.
There was no sign of the gasket, probably why it was loose, but since the early version didn't have one I dob't think I'll bother.
Many Thanks
mipster
