Pollen Filter
pikecrazy
Pollen Filter
Unread post by pikecrazy »
Is it neccesary to use it or can it be left removed ?
Dave Bamber
Unread post by Dave Bamber »
I take it your Xantia has aircon? If yes, you need it. Here is a picture of one after about 6 months.
They cost about a tenner from GSF.
Robin
Unread post by Robin »
Most definately use one. If you get any leaves in the system or other debris you will damage the fan and heater matrix.
Stempy
Unread post by Stempy »
I replace mine every 6k miles, that way you catch it before it starts to pong.
DoubleChevron
Unread post by DoubleChevron »
How do you remove the pollen filter.
It has most certainly never been changed in mine, and it can stink ....
seeya,
Shane L.
pikecrazy
Ok will order one .........Thanks
danielsydney
Unread post by danielsydney »
My C3 pollen filter has been changed on one of the services. I think they are only worth about $15AUD
x 1476
Shane,
Remove the carpet under the dash in the passneger footwell (4 or 5 screws) then remove the long thin cover under the dash (another 3 screws) then pull the filter out.
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by RichardW</i>
Shane,
But not always. Some slide towards car centre. No screws.
Kowalski
Unread post by Kowalski »
My Xanta has a long thing cover that slides. It takes a rather excessive amount of force to move it, so much force that each time I've removed it I've been sure that it was going to break.
