I would welcome some information on the new type of refrigerant and what if any components might need to be changed from the current set up I have on my 92 BX 1.7TZD.
The compressor is u/s so that would be an initial invetsment but i believe that the need stuff runs at a much higher pressure so what else might need to be changed to get the aircon running again.
If it is going to be a major outlay then the window is a reasonable altenative.
Regards
Colin
BX Aircon refrigerant
littleredrooster
bernie
You do not need to change the compressor.
Just fit a new filter/receiver, new pag20 oil and renew all o'ring seals.
Have a look at http://www.sanden.com/support/pdf/sd7servicemanual.pdf
section 19
Good luck
section 19
Good luck
beano
