Cant get the horn...
jpacoupe
Unread post by jpacoupe »
no, I dont want --adware link removed--, I want to know where the horn is on my 96 xantia estate.
its currently about as loud as a mouse's fart and I'd like to change it for something other road users might actually be able to hear.
Can someone tell me where it is and if I'm able to 'upgrade' it?
Kowalski
Unread post by Kowalski »
Xantias have 2 horns, one lives in the left had side front wheel arch, where it gets covered in spray and dirt and rusts away. I think its underneath the wheel arch liner.
The second horn is under the front bumper I believe.
jpacoupe
2 horns?
Do Citroen ever do anything normal?
Thanks anyway
AndersDK
Unread post by AndersDK »
Like in the BX then.
My experience from the BX is to leave the old horns where they are, then identify the feed wire, cut it off and pull it back into the engine bay.
Then simply fit a new standard (£8) horn and connect the feed wire.
jpacoupe
Sounds easy enough.
So if you see a Xantia with an ships fog horn bolted to the roof, it'll be me !
PARRRRRRRRRRRRRRRRRRRRRRRP!!!
ACTIVE8
x 6
Unread post by ACTIVE8 »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by jpacoupe</i>
2 horns?
Thanks anyway
No, but that's why we like them ! [:D]
uhn113x
x 3
Unread post by uhn113x »
2 horns?
Do Citroen ever do anything normal? <b><i>NO</i></b>
Thanks anyway
Hows about the DS, then - that has FOUR. [:D]
Light pull on the stalk, you get one electric horn.
Pull harder, you get the other electric horn and two air horns! [:0][:0]
Lots of dBs !!
jpacoupe
4 horns?
now you're just showing off ...
ACTIVE8
x 6
Now I like that !
At least others will here you ! [:D]
weety
Unread post by weety »
you horny devil you
vanny
Unread post by vanny »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by AndersDK</i>
So your the wiring screwer upper?
(Sorry, spent last week fixing the wiring on a LandRover that had been butched by the Police, got a thing about doing the wiring right, but botch the rest :D )
