Sphere specs
bernie
Sphere specs
Unread post by bernie »
Does anyone know a site for Xantia sphere specs?
The link for BX is here
http://www.tramontana.co.hu/citroen/sus ... spens.html
And these are from a French Activa site but the other models would be good.
They do not appear right on this page but if anyone wants the EXCEL version I'll email it [:)]
SPHERES XANTIA ACTIVA (MAJ 27/03/04)
Phase Année Motorisation Caractéristiques Suspension AV Suspension AR Accumulateurs Anti-dévers
principales "additionnelle
(Hydractive2)" principales "additionnelle
(Hydractive2)" "principal
(conjoncteur)" "anti-affaissement
(SC-MAC)" "AV
(SC-CAR)" "AR
(SC-CAR)"
Tolérances pression (bars) (+5 / -20) (+5 / -25) (+5 / -10) (+5 / -10) (+5 / -32) (+5 / -20) (+5 / -32) (+5 / -10)
1 -> 05/95 2.0i 16V Volume (cm3) 450 450 400 400 400 400 400 400
Pression (bars) 45 75 30 55 62 50 62 30
Membrane M M U U D U U U
Amortisseur (trou mm) 0.7 Non 0.6 Non Non Non Non Non
Réf. Citroën 5271 62 95,669,124 5272 42 5276 06 95,666,763 5293 04 5277 04 5277 03
Réf. SNRA (échange std.) C00284 C00008 C00264 C00009 C00001 C00006 C00006 * C00010
Réf. SNRA (neuves adapt.) XA245FK XA175FQ XA230RB XA155RQ RP162DP XA150RU XA162FE XA130RR
Réf. DEPA 2349701 1347200 2349751 1347500 1346000 1347400 1347600 1347700
"06/95
-> 12/97" "2.0i 16V
2.0i TCT
2.1 TD 12V" Volume (cm3) 450 450 400 400 400 400 400 400
Pression (bars) 45 70 30 55 62 50 62 30
Amortisseur (trou mm) 0.7 Non 0.7 Non Non Non Non Non
Réf. Citroën 5271 62 5276 09 5271 46 5276 06 95,666,763 5293 04 5277 04 5277 03
Réf. DEPA 2349701 1347001 2349051 1347500 1346000 1347400 1347600 1347700
3.0 V6 24S Volume (cm3) 450 450 400 400 400 400 400 400
Pression (bars) 40 70 30 55 62 50 62 30
Réf. Citroën 5271 C7 5276 09 5272 42 5276 06 95,666,763 5293 04 5277 04 5277 03
Réf. SNRA (échange std.) C00294 C00008 C00264 C00009 C00001 C00006 C00006 * C00010
Réf. SNRA (neuves adapt.) XA240FT XA175FQ XA230RB XA155RQ RP162DP XA150RU XA162FE XA130RR
Réf. DEPA 2349900 1347200 2349951 1347500 1346000 1347400 1347600 1347700
2 12/97 -> "2.0i 16V
2.0i TCT
2.1 TD 12V
2.0 HDI" Volume (cm3) 450 450 400 400 400 400 400 400
Réf. Citroën 5271 62 95,669,124 5272 46 5276 06 95,666,763 5293 04 5277 04 5277 03
Réf. DEPA 2349701 1347200 2349851 1347500 1346000 1347400 1347600 1347700
Réf. Citroën 5271 62 5276 09 5272 46 5276 06 95,666,763 5293 04 5277 04 5277 03
Réf. DEPA 2349701 1347001 2349851 1347500 1346000 1347400 1347600 1347700
alexx
Unread post by alexx »
You can find specifications somewhere on this website
Activa uses equal suspension spheres as hydractive models (VSX, Exclusive) + two additional accumulator type spheres for anti-sway system - multilayer 450 ccm 45 bar front corner spheres, 400 ccm 30 bar rear (not sure whether it's 40 bar for estate or not) etc.
bernie
Thanks Alexx
Are you saying the 4 corner spheres are the same for Activa and HA2?
alexx
Activa has the same HA2 system like hydractive models without anti-sway system, including spheres
There is a difference between pre '96 models and post '96 models, the latter having suspension cylinders with increased diameter and spheres with lower pressure. Also, break hydractive models have 40 bar rear spheres instead of 30 bar (I'm not sure whether break Activa existed or not)
