help with wheel please
mucky
Unread post by mucky »
my front drivers side wheel is wobbely. I bought a track rod end and just looked at the job properly and found the track rod is fine but the ball joint under the bearing housing has gone. can this be replaced? nd if so what is it called so i can order a new one?
mucky
I forgot to say the car is a 94 xantia 1.9 td
arry_b
Unread post by arry_b »
Are you describing the ball joint? If you are, then they are in teh online shop:
N42414 BALL JOINT XANTIA 9.50
Kowalski
Unread post by Kowalski »
The balljoint can be replaced, part number N42414 is correct for the Xantia.
The ball joint screws into the bottom of the hub and needs a special socket and an impact wrench (rattle gun) to remove it, so if you don't have access to the tools, this may be best entrusted to a garage.
mucky
Hi thanks arry. i just looked but without a picture its difficult to tell!!.
It is a ball joint and its located under the bearing housing. it is on the end of a long mounting rod coming out from near the bulk head
mucky
Many thanks Kowalski.
I think thats the one. Can the tool be bought?
NiSk
Unread post by NiSk »
It's cheaper to buy the ball joint and go to a local indy with it - using a pneumatic impact wrench it only takes a minute to change.
//NiSk
Kowalski
The socket can be bought and should cost less than a tenner.
http://www.sealey.co.uk/PLPageBuilder.a ... uctid=8382
