I've just bought myself another project of a Xantia 2.0 16V (97P) listed below, which comes with the cambelt apparently snapped (haven't had a chance to look yet).
My other 2.0 Xantia has a perfectly good engine (mechanically) so I'm now pondering do I swop the cylinder heads or replace the engine as a whole?
Swapping engines will take longer and is a lot more grief, but I have this thought that when cylinder heads are removed the repair is prone to giving problems/failure.
So, the big question what would you do??
Swap the engine or cylinder head?
DLM
oilyspanner
stevieboy1
Stuart McB
Richard Gallagher
Thanks for the suggestions lads, the donor car has some sort of duff electrical connection which was there when I bought it. Several dealers had already looked at it before I got it and given up, now I've done the same. Basically the engine runs fine for several days/weeks then cuts out for 1-2 seconds then runs OK. So mechanics fine, electrics duff hence using it as a transplant.
What sort of timescale am I looking at for engine removal/refit on a Xantia?
