Some issues after replacing shperes
modi
Unread post by modi »
I replaced the rear spheres 2 weeks ago and checked the LHM level but since then the car doesn't sink everytime i switch off the engine even after leaving it till the next morning, and it doesn't raise after adjusting the ground clearance from the minimum to the normal position, any ideas?? thanks
bxbodger
Unread post by bxbodger »
This normally happens when you change spheres!!It sounds like air in the system- do the Citroabics ( up and down a few times ) and see if it makes any difference.
