I've replaced the bulb with a new one and also swapped it with the rh bulb to be sure, the fuse is ok , the bulb is ok, and there's no obvious loose wires at the bulb end,
Main beam (seperate bulb) works ok,
Any ideas please
Thanks in advance
Ian
406 no LH headlamp dipped beam
bikeboyz
arry_b
ianb
