Can anyone help me out I have need to know how to remove seized drum brake. I have removed road wheel hub nut but the drum is fast. Have tried levering, hitting it, but nothing. I am total unable to rotate the drum / wheel in any direction.
Any idears???
ZX sized brake dum
rossnunn
AndersDK
Stuart McB
dozer
Thanks guys
The three leggeed puller - are you taking about a 3-Pce / leg Gear Puller Set or a Universal Hub Puller?
I`ve slackened off the handbrake completely & can`t get to unhook the hand brake cables
The recover machanic said that the brake linings from 1 shoe could have come free and wedged under the second one. I quick drive round the block seemed to produce a lot of smoke from the drum!
arry_b
rossnunn
rashmore
sooty
wilkobob
Mine was like this when I needed it off. I found that one hand brake cable had seized solid, so I wiggled it about a bit to free it up, and drum more or less fell off (after a few taps with a large hammer). [:)] Dont know if this helps, but it isnt the first time ive seen it happen. Incidently, after soaking the handbrake cable in WD40, its still ok, although nearing retirement...
Since my car may be getting written off (was in smash a week ago, some plonker in a 4x4 thought it might be a good idea to play bumper cars)Im not too bothered about replacing the cable as of yet.
