Either side of the diff is an oil seal where the drivshaft enters. Whats the proper name for them and do GSF sell them?
BTW its for a be3/5 gearbox. NA derv pre 97
oil seals
Stuart McB
Diff oil seals. Easy to replace. After taking out the drive shfts just pull them out and replace with new. Sorry that's if its a Cit ZX etc. You'll need new gear box oil and GSF's stuff is OK. You can get them from any bearing factors. I found that I needed the crank oil seal for my Xsara and it cost only 76p from the main Citroen delaer so give you main pug dealer a call.
bad driver
Stuart McB
bad driver
