clutch
jason
clutch
Unread post by jason »
my clutch cable is nice and smooth wiyh the engine off but when i put the engine on it seems to grind slightly anyone ant suggestins,1.9td xantia
dan.2cv
Unread post by dan.2cv »
It's not the cable?
With the engine off the cluth isn't rotating, you're just releasing a stationary clutch. With the engine running the clutch is spinning, so if you're getting a different feeling clutch it's likely to be caused by one of the clutch components. I would imagine you're probably feeling some sort of vibration.
