306 Airbag Warning Light
Linchpin
Hey chaps, same old fault flashes for 5 mins then goes of... Im trying to find the wires under the seat,,, cant see them?
PowerLee
Linchpin
PowerLee
Linchpin
PowerLee
If the airbag light is on or flashing it means that the airbag & seatbelt pretensioners WONT work in an accident.
Make sure you have the radio code & shut the alarm system down first.
Disconnect the battery & wait 10 minutes.
Under each front seat is an orange connector plug with 2 wires.
Undo the plug, Clean the metal terminals with WD40 or similar & make sure the metal terminals are a tight fit together.
Once you have done both plugs under each front seat, Reconnect them & then reconnect the battery.
Then see if the airbag light behaves then.
If this clean up doesnt cure the fault, The next likely cause is the rotary switch behind the steering wheel, But it might pay to have the fault code read first before spending any money on it.
PowerLee
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by Linchpin</i>
Hmm will try it
Its an Aftermarket radio anyway
Whats an aftermarket radio got to do with the flashing airbag light?
The radio doesnt use the rotary switch behind the wheel.
Hmm will try it
