OK, been told my idle speed might be set slightly too high, but how do I bring it down slightly? Had my head under bonnet earlier but couldn`t see anything that could be adjusted. Car is a 2.0 16v petrol GLX saloon.
Cheers in advance for any help!
406 Idle Adjustment
PowerLee
Bosch Motronic MP5.1.1 is the system your 406 is running.
The idle speed is controled by the ECU & cant be adjusted without diagnostic equipment.
Your Steeper motor on the idle control valve might want cleaning out, Also give the idle control valve & throttle butterfly a good clean.
WD40 is very good & doesnt damage the engine.
Have a search for it using the SEARCH button at the top.
NOTE: You MUST re-set the stepper motor position after cleaning it for the ECU to learn the correct resting position.
Gotta New Pug
OK, searched for stepper motor info above, but only found a brief description to where it should be situated - at the front right of the engine and looks like a little 1 1/2" black box with lead connected to it, - I cant find it in my engine! I may sound stupid for asking but could anyone describe it and its location a little more clearly please as these modern engines are a nightmare for us that only had old bangers in the past!
Thanks for the info above and any further help!
PowerLee
Hi
Heres a picture of the Steeper motor on my 405 with the XU10J2 engine.
http://img.photobucket.com/albums/v201/ ... tepper.jpg
You have the XU10J4 engine on your 406, The set up on the throttle housing is very similar.
