WHATS A MAP SENSOR???
001272
Unread post by 001272 »
what is a map sensor and where do i find it on a citroen synergie 1995 n-reg model 2.0i??? plz help
turbolag
Unread post by turbolag »
Do you mean a MAF? It's a Mass Airflow Sensor, measuring the ammount of air being sucked in so the engine knows how much fuel to juice in. Find the air filter housing and it'll be attached to the rear of that with a connector on the rear.
001272
no i was told a map sensor
tomsheppard
Unread post by tomsheppard »
Manifold absolute pressure. Much the same thing.
dan.2cv
Unread post by dan.2cv »
a map sensor is a Manifold Absolute Pressure sensor. It will be wither screwed directly into the inlet manifold or (more likely) somewhere along the air inlet ducting on the engine side of the air filter.
Richard Gallagher
Unread post by Richard Gallagher »
A MAP sensor is a 'Manifold Absolute Pressure' sensor, does a similar job as described above but measures the 'Inlet Manifiold Pressure', which varies in accordance with the throttle position.
x 1044
Unread post by wheeler »
MAP sensor = manifold absolute pressure sensor.it enables the ECU (in conjunction with the inlet air temp sensor) to determine how much air is being drawn into the engine.cant remember its exact location on this model/engine but it will either be bolted directly onto the inlet manifold or it may be mounted remoteley with a small rubber pipe connecting it tho the inlet manifold.it can cause all sorts of cutting out & running problems if it gets conaminated with oil.
001272
thank u all very very much ne idea how much it wud cost for this vehicle???
bernie
Unread post by bernie »
On my GTI the MAP sensor was integral to the ECU.
Connection to the inlet manifold was l o n g rubber tube to under driver seat
alexx
Unread post by alexx »
On 1.8 16V it costs about 100 EUR here. A small piece of black plastics on the inlet manifold, made by Denso (Japan). Same type on many newer PSA petrol engines. On some models, it's Magneti marelli
wilkobob
Unread post by wilkobob »
Im glad someone has finaly stated what one is, cuz its been puzzling me a while now, cheers peoples!
Jshodgson
Unread post by Jshodgson »
I needed a new MAP sensor for my Saxo. It was a case of unscrewing the old one and screwing on the new. I wish I had known thta before Citroen charged me £40. I think the part was about £40 from Citroen.
Stuart McB
Unread post by Stuart McB »
Always better to try and get the part number and go straight to the manufacuter or an agent. Bosch and magnet marelli dealers are found in the yellow pages and on the webb. You all know I saved nearly £80 by going to
www.autoteknik.co.uk
001272
this car doesn't have a map sensor does it map sensors r only 4petrols
Twiss
Unread post by Twiss »
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by 001272</i>
I thought your car was a petrol if its a diesel its a whole different matter.
