Questions about HP cits - pleeease[:)]
Fellas, what makes an HP Cit wobble when:
a) accelerating while describing a turn;
b) moving straight ahead at low speed (2nd gear) and accelerating;
c) after height change, though it doesn't make it after a dynamic height change, i.e. with the car moving at a steady pace or small acceleration.
Thanks[:)]
Thanks[:)]
- My Cars: M reg Xm S2 2.1td Auto Exclusive. 269k and rising
L reg XM S1 V6 12v Manual SEi
L 94 XM 2.1 TD auto total resto
2008 Peugeot 207 Sw 1.6 16v hdi. 217k and rising
2010 Peugeot 207 SW 1.6 8v HDi 161k and rising - x 71
Possibly a drive shaft problem. My Xantia is dooing it at the moment, it complete wobbles while accelerating, and thats the whole dash/front end.
I had this not so long ago, and it was slightly worse, as the gear stick wobbled too, this turned out to be the PASSENGER side drive shaft. I now think my drivers side shaft is playing up.
Will get round to swapping it one day.
Paul
Paul
The thing is, it doesn't make it always. Sometimes its imperceptible others (until i stop, lower, then rise it again dinamically) it seems to be on the edge of falling apart.
I took the C5 the other day to the dealer, and nothing, just a made it a bit while starting to move on a junction, but the mechanic said it to be normal[?]
Having different spheres makes no difference to it as only the dampenning is softer.
I'll try and go again to citroën tomorrow.
Oh, one more thing, could torque steering lock be due to the shaft not beeing ok?
Thank you once again[:)]
My dads BX does very similar and it's the lower suspension arm bush (drivers side RHD) being worn that is the current theory. It started as a clonk on braking when reversing it has worsened to a bad wobble which overheats the tyre in a certain spot causing localised overheating of the tyre and eventually a bald spot and large blister. I at first suspected a bad tyre but it had done it with two now so this theroy was discounted. There is no apparent movement of any components withy the car sitting on it's wheels and I haven't jacked it to investigate further. I recon that there is movement of the whole suspension system with the wobble being caused by the wheel being out of balance and this moves the whole assembly causing the tyre wear.
I will keep you posted as to the outcome but the syptoms you describe are very similar.
Well, yesterday i loaded it with some wall tiles, around 200kgs, maybe less.
Boy, did she wobble like it was falling apart!
It seems to do this with some weight on the boot, an d the front beeing lighter.
I took it to Cit (guees what) and they say a little wobble on curves is normal or even on acceleration (but below 2k rpms and on 2nd gear?!)
Thanks guys
Thanks guys
