Hi just bought a '93 K reg 405 GLDT with 195000 miles on clock[:)]. only problem is that i get an orange warning light flashing on the left side of the dash, it doesn't stay on all the time just comes on intermitently. It looks like a bowl with a pipe coming out of either side of it. Does anyone have any idea what it is as i don't have a handbook and is it anything to worry about or could it just be a wiring fault?
Everything else is fine and the stop light doesn't come on when i drive it.
cheers
Glynn
405 turbo diesel
PowerLee
glynn25121100
PowerLee
Hi
The fuel filter is under the bonnet on the diesels.
There is a drain tap at the bottom of the filter housing to drain the water out of.
There is a fuel primer under the bonnet, It depends which fuel pump is fitted to the engine as to which way you prime it.
Theres a couple of different primers, Im not a diesel man myself, One of the diesel guys will be along in a minute with a better answer.
Dave Bamber
Warm up the engine. The fuel filter should be in a black housing with 4 Allen bolts holding the lid on, take the lid off and remove the filter. Clean out any muck inside and pop a new filter in, screw the lid down then give the primer bulb a good few squeezes until resistance is felt. (The primer bulb is on the LHS of the engine above cam belt housing)start the engine, it should start straight away but may misfire. Keep trying until it idles normally. Jobs a good'n!
glynn25121100
glynn25121100
woodhead722
