handy brake tip
crooser
handy brake tip
when replacing front pads on an xm or xantia and you have to wind the piston in on the caliper, slacken the bleed nipple on the relevant caliper until fluid seeps out.the piston will then retract very easy. don't forget to retighten the bleed nipple.
nick
dan.2cv
crooser
406 V6
I did this when i changed the front discs on the 406, only to still have an extremely stuborn calliper piston, and enough air in the system to have the brake pedal on the floor to have a decent stop[):]. Needless to say i changed the brake oil the same day at a local garage.
It depends how lucky one gets, really[:I]
