My 95 Xantia TD estate was starting a bit lumpy with some white smoke so bought plugs from GSF and changed them - well 3 of them anyway - all except no.1 - how do I get to it? is there an easy procedure (he asks in hope [:)]) I gave up after 1/2 hour as it was freezing out.
If anything starting is worse now still lumpy and lots of white smoke so I assume no.1 is the faulty one.
once revved for a bit everything's fine.
Thanks in anticipation
Shaun
Xantia glow plugs
np
Easy way???Not that i know of!When i did mine,i removed a few pipes from the fuel pump,then using a selection of spanners,some bent for better access,took about an hour to change it.With lots of swearing & cuts to my fingers.
Try using the glowplugs twice.IE,turn on ignition,what for light to go out & then repeat.If it starts better,like mine then its usally the plugs.
Also though,you could have a air leak in the fuel pipes.Before cold starting,try pumping the primer bulb,top left of engine bay(drivers side)when looking from the front.Pump it till it hardens,then if it starts better,you could have a small air leak in the system.Its cover`d on the forum somewhere.
davethewheel
vanny
Im assume that its just a simple mind slip and your talking about plug FOUR (the plugs, like the cylinders are numbered from the final drive end of a PSA deisel engine) and the problem plug is the one behind the mechanical fuel pump?
I've got to do this on mine eventually, but have done it on NA diesels without any sort of major problem, just lots of swearing and an hour to retrieve a socket that went down between the pump mount bracket and the block.
What i have noticed is that if i prime the hand pump, bleed a little on the fuel filter, then reprime, the car starts with much more ease and less white smoke. I just wonder if a fuel leak is a) making the situation worse b) the cause of the plugs to fail?
I did however do plugs 1 and 2 with cheapo replacements but the BERU plugs that came out where slightly deformed. hmmmm
Any suggestions?
Any suggestions?
NiSk
When you go to the trouble of replacing glowplugs it's really silly to not replace the leak-off pipes on the injectors at the same time. The original rubber piping literally disintegrates as soon as you touch it and you've probably got problems with air leakage here without knowing about it. Replace with modern nitril rubber instead and it will last the life of the car.
//NiSk
//NiSk
gecko
Hey cheers everyone - I was hoping for some magical technique I guess but after getting ripped off by a garage last summer with clutch cable and eventually spending a few times upside down under the dash replacing clips (following the helpful suggestions on this board) and eventually the cable and a metal clip from the guys in Gloucester myself, I probably should have known it would be another 'pig' of a job. For someone who could barely manage to check the oil before I had a Citroen you guys have really brought me on, [:-)].
Thanks for the advice about the air leak will check that out - Nisk - any idea where I get the nitril rubber version from or are they all that now?
Thanks again gonna have another crack this weekend, weather permitting - will let you know how it goes.
Shaun
Shaun
NiSk
gecko
Finally got the number one plug sorted and leak off pipes replaced. But still a lumpy start-up and alot of white smoke.
My mechanic tried applying power direct to plugs, bypassing the control box, and she started like a dream with no smoke - so is it down to the heater control box - we have a spare but mine's black and the spare is blue - are they interchangeable?
It seems my old plugs are fine too - so I now have a spare set
cheers
Shaun
cheers
Shaun
ActivaV6uk
stevieboy1
jeremy
I think there are 2 types of glowplug relay, the BX type which goes off with the light and the later type which keeps the plugs glowing after the engine starts. I think the plugs themselves are different too. Probably best to check with Online shop to see what goes with what.
having said all that I think the change was probably in 1991 or so so if your relay comes from a car after this time its probably ok. If it doesn't work properly (or fit easily) then age may be the problem.
Jeremy
Jeremy
jakeuk
i did the unthinkable and used inferior replacements which were great when first done absolutely on the button and smokeless starting but it did'nt last now less than a couple of months down the road she still starts on the first turn of the key but the little chuff of smoke is starting to return.
i think the key to a painless change is in the selection of tools
