Bleeding brakes on a 106 1.5D
kendo
Unread post by kendo »
I have recently renewed all the rear brake pipes, front to back, Problem is that i cannot get the system to bleed, I have changed the master cylinder thinking it was that, but it did not work, i had the master cylinder out and primed by hand, but soon as we try to bleed it nothing comes out the bleed screws, I would like to hear from anyone that has had some similar experience
cheers
ken
x 1056
Unread post by wheeler »
you might need to use a pressure bleeder on it.
kendo
Thanks Wheeler i will give it a try
kendo
i have purchased a pressure bleeder and it has worked a treat, thanks for the tip
