Laguna I ventilation burning smell
mire
Unread post by mire »
A problem with ventilation fan occured to my '96 laguna. When I turn the fan on, I can hear noise, it blows very weak and smells terribly on burning. I discussed it with one mechanic and he says that the fan motor has burned and it has to be changed.
Is there a possibility to fix this motor to avoid ordering (expensive) original part?
beezer
Unread post by beezer »
I think a scrap unit would be better. If it is burning it will have lost resistance and is not worth the cost of rewind.
mire
I suppose I will order new unit at the end. As I hear, the problem is not uncommon so I don't want to pay for something which will burn again soon.
I'll try to open my fan unit before that and if I manage to do anything with it, I will report it here.
