does anyone know how to get the whole unit out? The reflector is moving around behind the glass so I wanted to take the unit out and see if I can secure it. There is a bolt at the top which frees up the top edge but it is secured from underneath somehow.
Cheers
51 plate clio headlamp removal
beezer
There are a few different designs but the basic oval headlamp on later Clios have two screws at the bottom. You have to remove the radiator grille panel to gain access. If you have a headlamp adjuster inside the car you have to unhook the mechanism on the headlamp (should be a simple ball and socket). There will also likely be a bracket (B) holding the headlight unit to the wing which is there to assist assembly at the factory. You have to cut this apparently.
Good luck with the repair. I am hoping to do the same kind of repair to a Skoda Octavia unit. Silly money for a replacement.
commuter
beezer
commuter
commuter
Just for your info I discovered the reflector was loose when trying to change a blown headlamp bulb - which is also a pig of a job due to restricted space and large hands. Hopefully the car has gone before I have to change another! Up until this point I've been really pleased with the car, it's performance, economy etc and would recommend buying one. It's a bit small for me and my girlfriend as it was only ever bought as a runabout for me but is now our only car.
