Guys need help. as my name says, I’m a lucky owner of ’97 Xm 2.5 TD Exclusive.
Got problem with my speedometer and together with that I hear some relay knocking from time to time when speedo stops functioning.
Can anyone tells me if there is some connection between relays and speedometer and if there is, how to find this one, how to get to it?
Also, does anyone have any kind of diagram of location of all relays in the car?
Not even Haynes has this in it’s book.
Thanks in advance
XM relays
bobken
beezer
Here goes:
Fascia
F1 ABS
F2 Stop lamps, cruise control, water temperature control module
F3 Air conditioning system, heated rear window, door mirror heater, seat heater
F4 digital display (language selection)
F5 Engine running relay, audio unit, digital display, door mirror adjustment, cellular telephone, instrument panel illumination
rheostat, indicators, interior lamps, central locking, deadlock system, glovebox lamp, warning lamps
F6 Rear fog lamps
F7 Suspension control module, body movement sensor
F8 Digital display - language selection
F9 Electric window relay, sunroof relay, windscreen wipers, rear screen wiper, side lamps on warning buzzer, engine coolant
blower motor (slow speed), seat adjustment relay - front, over speed audible warning
F10 Side lamps, switch illumination, ashtray illumination
F11 Instrument panel illumination, switch illumination lamps
F12 Digital display - language selection
F13 Hazard waning lamps, diagnostic link
F14 RH tail lamp
F15 Spare fuse
F15 Engine coolant temperature control module ('96 model year)
F16 Spare fuse
F16 Engine coolant temperature warning lamp ('96 model year)
F17 Seat heater - rear
F18 LH tail lamp
F19
Engine coolant temperature control module, alarm system, air conditioning system, reversing lamps, instrument warning
lamps/gauges, speed sensor, interior lamp delay, engine coolant level control module, transmission (AT), mirror
adjustment control module, diagnostic link, catalytic converter control module
F20 Spare fuse
F21 Fog lamps- front/rear
F22 - Bridged to fuse 22
F23 - Bridged to fuse 23
F24 Seat heater - front
F25 Sunroof
F26 Electric windows -rear
F27 Alarm system, instrument panel, interior lamp, door lamps, boot lid/tailgate lamp, interior lamp delay relay, audio unit
F28 Seat adjustment - front right
F29 Spare fuse
F30 Seat adjustment - front left
F31 Engine control module, engine coolant temperature control module
F32 Headlamp washer pump, horns
F33 Heated rear window relay, door mirror heater
F34 Suspension adjustment, central locking, alarm system, central locking signal control module, engine coolant control
module
F35 Electric windows - rear, electric windows - front (anti pinch)
F36 Cigarette lighter
1 Fog lamps relay
2 Sunroof supply relay
3 Electric window relay - front
4 Windscreen wiper intermittent relay
6 Heated rear window relay
7 -
8 Seat heater relay - rear
9 Seat heater relay - front
10 Rear screen intermittent wiper relay
11 Indicator relay
12 Side lamps 'on' warning buzzer
Engine Bay
F1 EGR control module, glow plugs relay
F2 Air conditioning
F3 ABS
F4 -
F5 -
F6 -
F7 -
F8 -
F9 Headlamp high beam - right
F10 -
F11 Headlamp high beam - left
F12 -
F13 Headlamp low beam - left
F14 -
F15 Headlamp low beam - right
Fascia
F1 ABS
F6 Rear fog lamps
F14 RH tail lamp
F15 Spare fuse
F16 Spare fuse
F18 LH tail lamp
F19
F20 Spare fuse
F25 Sunroof
F29 Spare fuse
module
1 Fog lamps relay
7 -
11 Indicator relay
Engine Bay
F2 Air conditioning
F3 ABS
F4 -
F5 -
F6 -
F7 -
F8 -
F10 -
F12 -
F14 -
crooser
