Xantia ABS
Benito
Xantia ABS
The ABS light on the control panel has suddenly decided to remain on on a 1994 Xantia TD SX. Could this really be a fault with the ABS or could it just be a fault with the sensor? The brakes seem to work the same as before, i.e. the ABS seems to be working fine.
- x 1490
If the light is coming on, then the ABS computer has shut off - you will have normal brakes, but the ABS won't activate. Most likely cause is a failed wheel sensor - see other recent threads about solving this. Possible I suppose that the wire to the lamp has chafed through and is causing a short making the light come on.
Richard
Richard
NiSk
mbunting
My light would come on randomly, and for the last three weeks had been on all the time.
I checked the terminals on the ECU block at the weekend, and diagnosed a problem with the front right sensor.
On Monday, during heavy braking, some WD40 / Grease that was around the hub area decided to smoke quite heavily ( although there was NONE on the brakes / pads ) - to the extent that I was looking for a fire extinguisher.
Since then, the ABS has been working perfectly ( including the front right ) !!!
I suppose it saves me ( for the moment ) checking it all out again <g>.
Mat.
Mat.
avatar
Benito
