How to enter radio code?
JohnD
(Donor 2022)
x 72
Unread post by JohnD »
This may help, but it's for a 4035. When 'code in' appears, enter the 4-figure code using the preset buttons 1 to 6, eg: if the code is 1234, press buttons'1', '2', '3' and '4' in turn. If a wrong number is pressed, finish entering and the display will read ----. To unblock the system, press 'BND' button until 'code in' appears. If the wrong number is entered four times, the system will be blocked for at least one hour.
Chris55000
Unread post by Chris55000 »
Hi!!!
It's very easy to do, simply press preset button '1' then press the volume button up or down to step up or down the number to first no. of your code, then press preset button '2' then use the volume up/down key as before to select the 2nd number of your code. Repeat the process for the third and fourth nos of your code, then when you've
entered the fourth digit press preset button '6' - the set should give a short beep and 'code' should disappear to be replaced with the station display.[:)]
***Don't*** attempt to enter it unless you're certain you've got the right code, first time wrong it locks up for 1 second, 2nd time it locks up for 5 seconds, third time 30 sec, fourth time an hour and fifth time you've had it!!!!![:(!]
If you've not got the correct code I advise you to take the thing to a car radio specialist-they can read it out for about £10 or alternatively you might find a Blaupunkt
Code Calculator on the net - I found one but it had no crack to enable it!!!!
These sets are the Blaupunkt PH1C series, by the way.
Chris Williams
np
Unread post by np »
Do a search under Citroen for radio code.I sent another member a copy of the radio manual.He had locked his radio.He found a radio decode forum,joined,& within half an hour or so had his decoded.I cant remember who it was,but it was back in the summer i think.There was a link in the post to the forum.
meexi
Unread post by meexi »
if you give me the last 4 digits of the barcode i can give you the code
