I'm having trouble getting a smooth take off in first gear. I can make it happen, but I have to release the clutch pedal SO smoothly. It's as if the spring is too strong and I'm fighting with the clutch pedal.
There seems to be no tolerance. You ever release the clutch pedal at the perfect rate or you feel the judder.
I have no other clutch problems, so think I would see an improvement if I had a weaker spring.
Any ideas/comments?
Xsara Clutch Pedal Spring
Check the mountings for the engine and gearbox first, if they are ok you could try a new cable just incase the old one doesn't slide too well, but I suspect the actual problem may be with the clutch mechanism its self.
The actual pedal spring doesn't come into play as far as the feel and smoothness of the clutch goes, simply because of the much greater power of the diaphragm spring in the clutch mechanism, thats the spring you can feel, not the one on the pedal.
If the mountings are ok and a new cable doesn't help then you are pretty much stuck with it, short of having a new clutch fitted at any rate.
Dave
Dave
Just 30,000 miles. I'm pretty sure and would expect it to be the orginial clutch. As I say, no other problems at all (gear engagement/slipping). I'm taking it in for a service in a week or so, so will run it past them. I doubt there is much they can do without dropping the gear box. The cable is new, so it definately isn't that.
