Hi!
Fellas i'm considering acquiring a subwoofer to put inside the C5's huge boot. Nothing fancy, just for optimizing the overall sound inside the car, as i'm going to change the radio to a JVC unit, KD-G701.
But, i would need to put also an amp for it, and it needs a direct connection to the battery, i think it's a 6mm dia. cable.
Does anybody know where i can find a pass-through on the firewall for it?
Many thanks!
passing a cable through firewall
- x 1056
JohnD
- x 72
Consider running beneath the car. I needed three cables from the battery to the rear of my Xantia when I was wiring for caravan towing. I took the power from the battery via three in-line fuses, then into the conduit that runs the length of the car. At the back end, the wires went through a grommit into the boot.
406 V6
Hmm i thnk i have a rubber seal on the bottom of the spare wheel housing.
I thought about this alternative way, but i'm affraid the cable will, with time and vibration, crack the plastic and make contact with the chassis.
Beeing an HP, i should take all the ususal precautions to work under it, right?
Many thanks for your advices
np
jeremy
If you are concerned about chafing then either find a special double insullated cable or use som trunking or sleeving. Split trunking is available and much easier to fit. sleeving is cheap but make sure it is plenty big enough if you intend to thread it - its not easy if its tight! Also plenty of grommets and other anti chafe devices from places like Maplins.
make sure whatever you do is firmly secured (not necessarily easy under the floor unless you fasten some clips to the floor )(using pop rivets only just long enough so that the tails get lost in the carpet foam)
jeremy
jeremy
JohnD
- x 72
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by jeremy</i>
jeremy
No need on the Xantia. There's a plastic conduit already fitted which encloses all the pipework. There's room to pull through at least three 17amp cables.
jeremy
