I have a 2000 model Xantia 2 litre HDI. It has just started to flash the "STOP" message on the dash and the warning lamp on the temp guage flashes. I have checked the oil and water levels and they are fine, the water is clean etc. The warning will come on as soon as the engine is started, before its got any heat into it. The engine runs fine, no smoke, no vibrations, no nasty noises, starts first time etc etc. When the lamp came on I was driving home, the temp needle was just below 90 (as always), so I have no idea what the problem could be.
Any ideas?
Xantia HDI temp warning lamp
pwatson
Strangely enough my wife's Xantia HDi did this last week. She rang me up in a bit of a panic half way back from the supermarket to ask what she should do - I said to drive home slowly and I would check the levels when she got home (3 miles or so)Anyway, by the time she got home it had stopped, water levels and temp were OK and it hasn't done it since. I also wonder what it means
Stempy
- x 1056
MW
My 1.8 16V did it a few years ago, just after midnight on the M4, in the rain. Nice! I pulled over, found no sign of anything wrong (no bubbling noises, antifreeze smells etc), and so I carried on at a steady fifty. In about half a mile it went out and stayed out. The next morning I unlugged and re-plugged the sensor, and I assume that was all it was because I never had it again.
rossd
Simon Canfer
