Hi, i've recently bought a Xantia 1.9td that has 62000 miles on.I just found out the hydraulic pump is leaking on in and I was wondering if there was any way of servicing the pump or is the only option to buy a new one?
Ive also heard that there is more than one pump to fit the Xantia. Its a 1994 model - does one fit all or are there different variations?
p.s is it hard to change a pump? I dont even know where it is, i got my mechanic to check it out!
Thanks, James.
Citroen Xantia Hydraulic pump leak
Robin
Pump changes are not toooooooo frightening but first make sure the connections and seals are good. They run at very high pressures and a slight leak is quite possible from a failed seal or a loose connection.
Yes there are a couple of options but I understand easily identified. Good luck and welcome. Robin
