Ordered clutch T18910 / 2004 G5
Received Clutch N18914 (for VISA but claimed to be interchangeable.)
Old cluch had outer diameter of shaft/splines approximately 17,5 mm and 20 splines
New clutch had outer diameter of shaft 20,5 mm and 18 splines
Car 2052 XS 86 model 1360 XY 8 engine number 0837981.
Any idea how I can get a correct clutch for this engine?
205 XS Clutch did not fit
bikeboyz
Its difficult to see from the online GSF catalogue, but for the 1986, 1360cc 205 models there is only the one clutch, it is common with the 954 xv8, 1124 xw7, 1360 xy7 xy8 engines. The 18 spline clutch is either 21, fitting G1, F1, E1 engines, or 20.8 fitting the XU/XUD engines.
The engine you have is the Peugeot design, the clutch you got I think was the one for those with the old Simca/Talbot clatter engines from the likes of the 309/Horizon.
Not sure if this is a Valeo number, but try 003262 or QH QKT626AF.
The only other possibility I can see is GSF N18914, which fits Visa/BX/C15 all using the same series of pre-TU engines that you have. My quick X-ref shows this as the same as 205/104/Talbot Samba.
