how do i remove xantia o/s wing, easy job?
mattpc
Is it an easy job to remove the O/S front wing from my Xantia TD and how do I do it please? I've scratched the current one and am thinking of replacing the whole wing rather than touch up the existing one. Anyone got any tips please?
BrianM
As they are bolted on they are quite straight forward. First remove the under wing protection. As far as I remember you need to use a torx driver to undo the screw that hold the panel under the headlamp to the wing. You need to get at this this from under the wheel arch. When all the studs are out, the wing should come off with a little persuasion (in order to break the sealants).
Brian
Brian
