i have lost all lights on my 1996 xantia 1.9td.
None of the headlights work or sidelights front or back.
The brake lights work and the headlights flash if the alarm is activated. no dashboard lights work either.
The keypad immobilisor also seems to be dead but the car starts without no code being entered.
Are the problems linked and does anyone have any idea as to the cause all fuses appear to okay.
lost all lights
Robin
Have you had any problems previously?
Do all other electrical circuits work correctly?
I am thinking aloud here so bear with me........
The bypassed immobiliser puzzles me because there has to be a constant supply to the shut off solenoid unless the immobiliser control unit has failed as a result of some other trauma possibly related to the lights failure.
Could this be a failed light switch on the steering column?
A failed lighting relay, loose, damaged possibly?
However I don't think the sidelights and dash lights go through a relay - or do they?
Come on someone help us out here!
Robin
Robin
redalan1971
AndersDK
'96 Xantia does not have relays in the lightings circuit other tha the alarm flasher and any dim-dip relay. I suspect a problem in the feed to the lights switch.
More schematics on : http://citroeny.cz/servis/
redalan1971
beezer
redalan1971
yes i have checked them and there is power at all of them but the one you highlighted is where i am going to start my tracing as it feeds all the circuits that have no power on the internal fuse box.
you dont know by any chance if it feeds a relay that may have packed up the haynes manual doesn't say what relays are what.
beezer
It doesn't seem to except the rear fog light relay. Here is a run down of the fuses and relays in the engine bay:
F1 ABS relay
F2 Cellular telephone
F3 Engine coolant blower motor
F4 -
F5 Engine coolant blower
F6 Headlamp washer delay relay, fog lamp relay
F7 Engine control module
F8 Suspension control module
F9 Fuel pump relay
F10 Oxygen sensor relay
F11 Headlamp washer control module
F12 Headlamp high beam - left
F13 Headlamp high beam - right
F14 Headlamp low beam - left
F15 Headlamp low beam - right
A Alarm system switch
B Alarm system switch
C Fuse box, alarm system relay
D Lighting switch, rear fog lamp relay, immobiliser
E Engine coolant blower motor relay
F Engine coolant blower motor relay
1 Air conditioning compressor clutch relay - Temperature cut off
2 Air conditioning compressor clutch relay
3 ABS relay
4 Fog lamps relay
5 Cold start timing advance relay
6 Starter motor relay - Automatic
6 Glow plug relay - Post heating
F1 ABS relay
F4 -
F9 Fuel pump relay
3 ABS relay
4 Fog lamps relay
beezer
The fascia fuse/relay layout should be :
F1 Audio unit
F2 Coolant blower control module, instrument panel, diagnostic link, lights on warning, over speed warning, cellular
telephone warning immobiliser, vehicle speed sensor
F3 Headlamp low beam relay, suspension system alarm control module, alarm horn
F4 Side lamp - left, tail lamp - right
F5 Heated rear window, seat heater
F6 ABS, cruise control
F7 Horn, trailer socket
F8 Bridged across to F23
F9 Side lamp - right, tail lamp - left
F10 Electric windows, rear
F11 Sunroof, seat heater
F12 Reversing lamps, air conditioning system, air conditioning compressor clutch relay
F13 Seat adjustment
F14 Engine control module, engine coolant temperature control module
F15 Alarm system relay, interior lamp delay relay, boot lid lamp, diagnostic link, audio unit suppressor
F16 Cigarette lighter
F17 Alarm system control module
F18 Rear fog lamp
F19 Instrument panel illumination
F20 Air conditioning blower motor
F21 Central locking
F22 Sun roof, door mirror adjustment electric windows - rear, central locking system, seat adjustment
F23 Bridged across to F8
F24 Windscreen wiper motor, windscreen wiper delay relay, transmission selector lamps
F25 Audio unit memory, clock, central locking signal control module, seat adjustment relay, alarm system LED
F26 Hazard lamps switch
F27 Electric windows - front
F28 Rear screen washer motor, rear screen wash/wipe switch, rear screen intermittent wiper relay, stop lamps switch,
indicator relay
F29 Heated rear window, door mirror heaters
F30 Interior lamps, glove box lamp, electric windows, instrument panel
1 Seat heater relay
2 Horn relay
3 Electric window circuit relay - front
4 Rear fog lamp relay
5 Sunroof motor relay
6 Electric window circuit relay - rear cut-off
7 Electric window circuit relay - rear
8 Alarm system relay
9 Heated rear window relay
10 Indicator/hazard warning lamps relay
11 Side lamps 'on' warning buzzer
12 Windscreen wiper intermittent relay
13 Telephone warning buzzer
14 Over speed warning buzzer
15 -
16 -
17 -
F1 Audio unit
F13 Seat adjustment
F18 Rear fog lamp
F21 Central locking
indicator relay
1 Seat heater relay
2 Horn relay
15 -
16 -
17 -
redalan1971
NiSk
