Windscreen smearing.
Stuart McB
I have recently replaced thw front screen wipers on the Xsara (bought Bosch) as the old ones were leving a sort of misty smear [:(]. Now I've cleaned the screen with all sorts of stuff from white spirit to the official stuff as usued by the Queen, but no difference [:(]. Now I've read in a motoring magazine that 'sugar soap' is the best stuff to use. Also read that half a potato rubbed on the glass is good [?]. Any thoughts on how to clean this grime off. Should just metion the Queens stuff is Autoglym glass cleaner.
Richard Gallagher
beezer
If you can get hold of Vienna chalk then this method works well:
'Puff' the chalk over the screen then use a mixture of one part vinegar to two parts water and polish the screen. Allow to dry then polish off the deposit. Wash the screen with vinegar and water again. Vienna chalk is available from violin makers' suppliers. I believe it contains more sulphur than French chalk. Talc and French chalk work but not as well. You need plenty of elbow grease but it is worth it.
dan.2cv
Sounds like you've had some sort of grease/oil contamination (made worse by using white spirit) I made the same mistake once by using parrafin.
The chalk idea sounds good because it is both abrasive and absorbent and the vinegar acts as a solvent. You could just use as stronger solvent such as acetone of thinners, but make sure they are pure (ie, panel wipe) and don't use nail varnish remover as it will contain moisturisers. (another lesson learnt!!)
Just watch the paintwork though!!!
Once you've solved the problem, cream glass cleaner will be suffice and is far better than the instant spray stuff as it contains chalk and solvent.
Stuart McB
user_3150
- New User
NiSk
cornishbx16v
and dont forget to clean your wiper blades![:)]
i have found that to keep good clean screens to add a window cleaner spray liquid in to your screenwash, i have tried many things over the years, and as a valeter by trade i have heard many many things from different reps on how to keep screens clean, but i have found that in with the screen wash i pour half a bottle of fast glass as it dries non smeary on the screen! but it is also very inportant to clean your wiper blades often as they get a build up along the 'wiped' edge!!
mikeg
wrinklet1
if you want to clear a smeared windscreen, buy yourslef some Holts Mixtra (or renamed Screenies, but not wipes) if you phone Holts' up at Stockport, they will tell you the nearest stockest to you.
It cleans anything off you windscreen, I have used it for over 10 years now, cracking for clearing diesel of glass too
http://www.holtsauto.com/
Paul
Paul
wrinklet1
leonard1
cornishbx16v
wrinklet1
NiSk
