405 runnin well rich
cavguyuk
Unread post by cavguyuk »
hey guys i have just got a pug 405 done all the mot work apart from the emmisions are at 11-12% im not too hot on these engines but have replaced the coolent temp sensor and checked the airflow temp sensor changed the fuel pressure reg and the plugs etc and it just doesnt change. the problem is identical to this guy-
http://www.andyspares.com/discussionfor ... PIC_ID=872
this is the engine!
thanks for any help.
tonespeed1999
Unread post by tonespeed1999 »
how old is the car,looking at the picture you have supplied it looks like a 1990-91 model?.this engine and injection/fuel system was used in the citroen bx range.from what i can remember there is a small unit bolted to the drivers inner wing with a screw slot in it.this can be turned to lower the mixture.if the vehicle is fitted with a catalyst and lambda probe it will need to be checked with suitable diagnostic equipment.
PowerLee
Unread post by PowerLee »
Hi
405 with XU9J2 D6D engine & Bosch Motronic MP3.1
I notice you have an aftermarket airfilter fitted, Have you tried to adjust the mixture setting?
Also that brake fluid looks like it really wants changing!
cavguyuk
the mixture adjester i belive is the one on the alu panel next to the battery! i have adjusted this and changed it it makes no differnce, yeah its a 1990!i have adjusted everythin its been to a garage on a gas analiser the whole time i adjusted it nothing changes i have also made sure all vacume hoses etc are clear and no leaks!
PowerLee
The mixture adjustment screw is behind a tamperproof cap on the side of the airflow meter housing.
The idle speed adjusment screw doesnt have a cap over it & is on the top of the airflow meter housing.
Have you adjusted the correct screw?
cavguyuk
thanks for the reply mate but if u look at the photo it doesnt have an airflow meter its a map sensor type. and yes i have tryed adjustin both screws.its well well well out! could it be something to to with the throttle sensor not being corectly adjusted!?
