my xantia 1900 td October 1998 have one problem.
When I turn the steering, the system start to vibrate. This appear also if the steering is not to the end of the travel.
TKS Maxx
xantia 1900 td steering problem
AndersDK
The STOP lamp has not been trying to tell you a tale ?
The first thing to check is the LHM oil level, but a low level should bring on the STOP lamp.
I'd say a slipping drivebelt to the pump would do this. This would commonly be heard as a sqeaking, but could be hidden by the diesel clatter from the engine.
Try have the car parked, then open the bonnet and listen for any common drivebelt sounds when an assistant is turning the wheels.
Any history on LHM oil change & filter cleaning ?
jeremy
