ax speedo cable
brianr.uk
ax speedo cable
today i replaced all four dash illumination bulbs on my sons 1994 ax salsa.problem is when i fetched the instrument panel out the end of the speedo cable came apart.on putting it all back together i find the speedo doesnt work now.according to the rp number and gsf parts list it should be a split speedo.any tips on changing the top bit.this problem is normal for me,do one job create six.[xx(]thank you all in advance..brian.
bikeboyz
Only tip I can give is doing a speedo cable on a '93,106D, which was fairly straight forward. On the small Pug, my dealer advised fitting a 405 cable as they have exactly the same fittings but is slightly longer making it easier to navigate through the dashboard. The extra length also makes fitting to the back of the speedo easier. I would assume AX would be the same as 106 in this respect.
AndersDK
