Urgent
bad driver
Urgent
Unread post by bad driver »
What gearbox is in a 309 glxdt its K reg. Thanks
beezer
Unread post by beezer »
Should be a BE3.
bad driver
Thanks, another question, what size clutch is in a 306 1.9td pre 97.
beezer
Don't know actual size but it is not the same as the 309 you mentioned earlier. Try GSF. 306 clutch is dearer than 309.
bad driver
I asked about the 309 box as I need a speedo housing for a be3, so thats one prob solved. Then next is finding out the size of a td clutch so I can find a clutch the same size and fitment but with push operation rather than pull for a project
Gringo
Unread post by Gringo »
Hi! Up to 01/01/1992 on 309 (XUD engines) clutch mechanism size was 200 (DIAM). This clutch is suitable for 205, 309, 405, 406, 306, Partner with BE3 gearboxes.
