ZX 1.9D Can I disconnected the immobiliser?
pdhaynes
Unread post by pdhaynes »
If you can help, please give me some suggestions. Is there a way to disconnect the immobiliser?? I’m totally baffled with my intermittent ignition fault.
Thanks.
wilkobob
Unread post by wilkobob »
Ive heard that once engine is running, disconnecting the keypad disables the imobiliser, but not sure if it actually works having not tried it. Also, if you read the other post to do with the ignition system, the imobiliser wont stop the engine turning over, just cuts off the fuel supply.
Simon
