I've been looking at getting some oil temp and oil pressure gauges. I assume that I can replace the standard oil pressure warning light switch (located at front of cylinder block above oil filter housing) with a new oil pressure gauge sensor (and by fitting a t-piece adapter I'll be able to retain the original switch and the fuction of the dash warning light, right?) but where would I locate the oil temperature sensor?
Cheers.
Oil Gauges
sooty
