xm abs sensor
xm abs sensor
does anyone know the pin numbers on the ecu for the abs sensors on a 1995 xm 2.5?my mot is due in two weeks and i have the dreaded abs light on.
The set up on a 96 model is as follows:
H29 ABS warning lamp
S13 Brake pedal position (BPP) switch
X1 Data link connector (DLC)
A16 Electronic control unit (ECU)
F Fuse
Y22 Hydraulic modulator
K38 System relay
B19 Wheel speed sensor, left front
B21 Wheel speed sensor, left rear or single
B20 Wheel speed sensor, right front
B22 Wheel speed sensor, right rear
F Fuse
K38 System relay
