I have now reached the conclusion that the Citroen ZX wiring design came from the back of a Corn Flakes packet.
When i try to open the sunroof the only thing that happens is the little red led under the clock flickeres. I've been through every fuse i can find (while trying to sort out another electrical problem) and they're all fine plus everything else on the same fuses as the sunroof still work so i'm taking that as proof that the fuses are ok.
what am i missing??
and what is the red led under the clock for?
and why is the clock so dim?
ZX sunroof not opening
Stuart McB
marty_t3
wilkobob
red light under clock is to do with alarm, flashes whn its armed, flashes v. fast if the alarm has gone off, and also indicates wether interior scannin is on or off. My guess with this problem is the sunroof mechanism has seized up (has a similar problem on an old zx estate i had). The light is prolly flashing cuz its draining all the power trying to move. Clock dim cuz bulb has blown? these are just my guesses.. hope they might help. Simon
marty_t3
VisaGTi16v
its under the plastic bit inbetween the sun visors where the electric window switch is and the interior lights. Couple of star drive screws, oh and ive got a working motor if you need it
also the clock is really dim when the ignitions off, goes v.bright when ignition on so mayb its not seeing the ignition switch?
