24volt stereo
np
24volt stereo
My dumper truck at work runs a 24volt system.The stereo in it is a 24v Clarion unit,which is no good.I have a new 1 but it is a normal 12volt unit.I`m going to check tomorrow with my multimeter,but i dont think there is anything 12v in it.How can i reduce the voltage to get 12v?Our new dumpers have a reducer in them for the 12v stereo & powerpoint,but i cant get one of them & its a fairly big unit.Is there a small inline reducer or something i can get?Any help would be great as i`m feed up with no sounds for 9 hrs a day.[:(]
Failing everything,i `spose i could get a small car battery & run it off of that.Thanks[:)]
martyhopkirk
Dropper resistors i suppose - Thats how the majority of 24v - 12v adaptors work.
Funnily enough im just scratcing my head trying to work out the correct resistor to use to drop 12v to 3v to drive a blue LED - Used to do these sorts of calculations a lot.
Use 1W resistors if going this route ( I would anyway). Someone else may be able to suggest another method. Most truck stops and CB radio shacks (B&D @ Forton services for instance) will have 24v to 12v droppers.
dnsey
- x 19
dnsey
- x 19
Sorry, Marty, dropper resistors on their own won't work, as the current draw varies considerably, so a resistor which gives 12V under heavy load would allow too high a voltage when, for example, the output is low during a quiet passage. It needs a proper regulator circuit.
For your LED dropper, use the LED specs to calculate the required volt drop and current (don't go too high on this), and use Ohm's law: R=V/I
bikeboyz
You will need a Voltage Dropper designed for use in a commercial vehicle, available from any good truckers shop or CB radio outlet. Try http://www.kcb.co.uk they have them starting at £15, or maybe high street store like Maplins.
np
tomsheppard
blue Led Vf= 3V. Vreg =14.4V. Drop across resistor= (Vreg-Vf)= 11.4V Iled
=10mA. V/I=R
11.4/.01=1140 Ohms.
Nearest preferred value is 1.2K
If that's too dim,and the led will do 20mA then 600 Ohms,
or if too bright, 2.4K.Maplins now only sell resistors in tens so buy ten 2k4 resistors and wire two in parallel for 1200 and four in parallel for 600.
=10mA. V/I=R
11.4/.01=1140 Ohms.
martyhopkirk
Thanks Tom - been a LOOOOONG while since i did calculations like that. It comes as no surprise to hear my B-Tec PSU project went BANG in a big way when i first powered it on in 1988 as I wired a huge .5 farrad elecrolytic in the wrong way round.
Domestic wiring - much simpler affair, - tellys, videos and radios on the other hand - buggered if i know what goes on inside its all witchcraft to me!
Now bodies, THAT is simple.......
np
Well,i checked everything inside today with my multimeter,its all 24v.But checking the batterys i get 14.1v from one,11.7v from the other.I think i will run a wire from the battery with a inline fuse to the stereo,its only 3ft away.I have a earth point next to stereo,& theres only 2 speakers,so 6 connections in all.If not,KCB do a reducer fo £13 that plugs into a 24v cig lighter,with a 12v cig lighter outlet.£18 all in for next day delivery.
tomsheppard
vanny
martyhopkirk
Unsure of that - apart from odd voltage sealed LA bateries used in some alarm installs only other ones i have come accross are 6v DC - old Spugs and submarines (friend of mine - BOB has his workshop and cottage wired up (wia an expensive invertor) to an arsenal of HUGE (and i do mean HUGE) old 6V sub batteries which are charged from a couple of large solar panels and a small wind generator. Cut his elcetrickery bill to less than half what he was using before.
Mind you this is the bloke who used some old drain pipes and polyethene sheets to make his own solar powered water heater... Looks bloody ugly, but works. Never even occoured to me that it would be 2 12volters. (permission to kick me up backside)
np
