Could I fit a 306 TD head (from mid '90s car) on my 1998 406 1.9TD. Is it a straight swap or more of a case of just technically possible but not easy?
Paul
Peugot 306/406 TD heads
bad driver
Are they both xud 1.9 turbo diesels,? Around 97 the 406 engine started to change as well as the 306 so there may be some differences. I am guessing you already have a head? just compare them see if they are visibley the same, no extra connections etc. Internally they should be the same if the external is the same.
